Old Mar 28, 2023 | 08:45 PM
Ddave's Avatar
Ddave
Default Re: Help both key fobs stopped working
Question for anyone knowledgeable in the SKREEM. ('05,roadster base, 6M)
I recently encountered the problem where key fobs both failed; turning the key in the door lock set off the alarm and engine turned over but stalled immediately. With the help of advice this forum, I unplugged battery, gave it some time, and when I reconnected power things seemed to work fine again (both remotes worked, car started...).
Question: did I successfully reset the SKREEM and I can expect smooth sailing here on out; or in people's experience is this problem likely to recur, and maybe even get more frequent? (I will replace the module if needed, but hoping to avoid it - SKREEM rebuild is $600 + my lost weekend(s) to do the work)
TIA for any insights.
