Old Apr 11, 2023 | 09:01 AM
mp3wizard's Avatar
mp3wizard
Default Drain off strips on roof not staying flush and brush strokes on touch up paint
Hi All,
I removed the 2 drain off strips on the roof with the rubber trim underneath because the metal was exposed, so I took them off to paint with touch up paint, I've fitted them back where they were but I can't get the trim pieces to stay flush, they keep popping up near the front windscreen end, Wish I just painted in situ.
I've got the small notched out piece near the rear windscreen which I assume is the correct way, they are quite curved.
I've put some glue underneath and 10kg weight for a a day, but they keep popping up, any ideas how best I can get them down for good? If I bought 2nd hand replacement ones would I have the same issue? They were fixed down properly before I removed them.
Also, I'm not too happy with the final look of the bodywork areas I've touched up with touch up paint, it's the correct stuff, but I can see brush marks, it looks different to the surrounding bodywork, I used the touch up paint sparingly, It's all dried on now, what would be the best course of action too wet sand it off or would I need to use a buffer type machine.
Any guidance appreciated.
