Old Apr 11, 2023 | 10:24 AM
zip439's Avatar
zip439
Default Re: Which brands of water pump have all holes threaded?
UnderTheSouthernCross Be advised there are several different length screws securing the water pump. It is helpful to lay the new pump near your work area and as you remove each screw place it in the new pump's proper position. When you get the old pump off the car you now have all the screws in their correct spots to reinstall. Easy to mess this up; Be careful.
