Old Apr 20, 2023 | 07:19 AM
zip439's Avatar
zip439
Default Re: Which brands of water pump have all holes threaded?
Originally Posted by UnderTheSouthernCross
Well the GMB came in......wrong part! Was for the supercharged motor. BTW the Cam sensor holes were unthreaded.
Now got a Gates.....right part, cam sensor holes unthreaded.
So I now have a set of taps to go with my torx sockets and bits, a torque wrench, and some blue threadlock.
Will draw up a template for keeping track of the correct bolt positions.
I'm ready to go with this over the weekend. Wish me luck!
GOOD LUCK! I to have a Gates water pump as a replacement on my Limited. It has 70,000 miles on it and continues to work fine.
PS The cam sensor bolts directly to the engine block at the #1 cylinder. There is a bracket (two screws) that holds the MAP sensor and the auxiliary air pump solenoid that bolts to the water pump. Perhaps it is those two holes that require tapping? I do not remember tapping any holes, but it was a long time ago.
