Re: Which brands of water pump have all holes threaded?
Just use the original bolt -- they will self tap.
Make sure to put the wiring harness BEHIND the water pump, not in front where it will be cut by the serpentine belt. Also make sure it does not get pinched to the block.
Common issue with first timers.
