Old Apr 29, 2023 | 03:15 PM
onehundred80
Default Re: SRT6 2005 gasoline smell when tank full
Originally Posted by IRJ
I am a new member with a low mileage SRT6 Coupe, purchased earlier this year.
I only recently filled the gas tank to FULL. I did not overfill and there was no spillage and overspill line is clear anyway.
When I parked the car in my garage for a while there was a smell of gasoline around the car. As noted this is not an overfill issue and there are no fuel drips underneath the car.
The problem goes away completely once the tank is down to 3/4s full.
Suggestions from members as to the possible cause and remedies.
Thanks.
Ian
A few drips from the pump nozzle as you take the nozzle out of the filler can sit in the gas filler cap compartment and it takes a while for it to evaporate. I have had it happen, not enough fuel to reach the overfill drain tube but you sure cab smell it but not in the car.
you could smell if the gasket between the car body and the compartment was leaking. That gasket has leaked before.
