Re: PO is a POS
Trunk latch will operate when 12 volts is applied
No voltage coming from connector to actuator when button pressed
measured the trunk latch actuator ohms per the manual page 23-151 or 3699 in the PDF and I am getting 6 ohms which according to the manual means the power top control module is bad.
Any other tests I should run on the power top control module before ordering a replacement. Visual inspection of connectors and board don't show any signs of corrosion or damage, but that doesn't mean anything.
