Thread: RCM relays???
Old May 6, 2023 | 04:53 AM
Romad's Avatar
Romad
Question Re: RCM relays???
You would have been wise to order the correct part number.
The correct part number is almost non-existant anymore! I searched the net for two days for a source without success. After looking at several data sheets 5706 is the best I could do "AND" as it turned out that's what PN I removed. I had already asked Pizzaguy if he had any spares and he said they were long gone. This RCM was intermittantly working showed no visible signs of problems. After ohming out the coils and contact continuity decided to "play" around with relay replacement. The relay, which I removed, was probably ok as it was working and the contacts were not pitted or discolored. Don't believe the fuel pump relay to be faulty. Thank you for the two links you provided.
