Old May 7, 2023 | 05:29 AM
DigiDog's Avatar
DigiDog
Default Re: Replacing Skreem Module Worth It?
Originally Posted by ZERACER
If it tries to start three times and then nothing it is probably the screem. If you disconnect the negative side of the battery for a minute and then reconnect it should repeat the three tries then nothing again. If not it is probably the RCM, a cheap and easy fix.
I agree with this prior post. If the car, however, does those 3 starts - there is a start error, it is not actual skreem problem. It is loss of syncronization between SKREEM and ECU. It usually has something to do with the battery voltage. Let me know if you need to get it fixed.
