Old May 13, 2023 | 05:23 PM
onehundred80
Default Door switch on console switch group
I wonder if anyone can help me please.
On the console there is a switch to lock or unlock the doors and hatch. My one failed at some time, I installed a new radio some time back but I do not think I buggered it up then. I tried a used BCM every thing worked as it had before, still no luck with the switch, so I left the BCM in place. The original is now a spare.
When I check the circuits all is fine, the resistor gives two Ohm readings 0 and another which I have forgot, I have two spare switches and they read the same. The switch is on the right side of the emergency flasher with another one on the left side. They make up a three switch module.
My problem is that I can get no power to the switch, and I have no idea where it should come from. I am out of my depth when it comes to reading the schematics. The twisted pair in the circuit going to he CLP/SSM have the colours wrong.
My question is does anyone know where the power comes from my best guess is the splice block 200. I just want to be sure.
Thanks in advance for any help.
