Old May 17, 2023 | 08:13 PM
manlaw38's Avatar
manlaw38
Talking Re: Secondary air injection pump
My Crossfire does same thing the air pump works and the check engine light comes on after driving car to one town over aprox 10 miles then I must reset the check engine light to have the light to go off. I bought a new RCM and it started doing this after about 10 months of having the RCM installed because it was doing this before I bought the new RCM. So I have no idea what could be wrong with it. The check engine light will come on once I restart the engine after I come home from doing errands like light driving, the check engine light doesn't come on right away. The code says that the air pump is at fault. I went to the junk yard bought a used air pump and it does the same thing you can hear the air pump engage once you start the car. My emissions is due next month and I need to fix this because I asked for an extension once already. Once the car is 20 yrs old I can get antique classic tags which exempts me from emissions test. The car runs great .Can't wait to get this over with. I have replace all the coil packs and spark plugs and plug wires all new injectors and I am soon to change the fuel filter before next month just for maintenance I have installed new clutch and all fluids have been changed from power steering to rear end and new trans fluid. once I get this fixed I want to put a larger throttle body off a V8 Mercedes which I have ready to install ,I love my little red coupe.
