Old May 25, 2023 | 02:04 PM
Shamrock's Avatar
Shamrock
Default Re: Door switch on console switch group
with the ignition switch in the run position and the doors closed and locked, momentarily ground pin 8. You should hear a slight click and/or see the lock plunger move upward. If not, you have an open circuit (broken/cut wire) between the BCM and pin 8
