Old May 30, 2023 | 06:32 PM
Ronman's Avatar
Ronman
Default Re: Scanned Fault Codes - p2312 & p2404
THe reason no one has responded might be two fold:
- You say there is some history here, but you don't tell us what that history is.
- The codes you are getting are apparently not impairing the operation of the car, making one wonder if they are legitimate codes.
As to the P2404, if you get to highway speed and set cruise, does it hold? If so, if you tap the brake pedal, does it cancel the cruise?
If both work, then the code is baloney.
It can also be the brake lights do not light up when tapping the brake pedal. Sometimes you cannot shift out of park if it is an automatic if the brake light switch is defective.
