Old Jun 21, 2023 | 03:25 PM
red_2005_convertible's Avatar
Default Re: Wipers Not Working
Hi JD,
It's probably your multifunction switch in the steering column. I just replaced mine - my brights haven't been working for years, but after the replacement they work fine. The multifunction switch also controls the wipers - mine worked fine. You have to get to remove the lower console panel to get to the connector. From there you probably could use a jump to check if the wiper motors actually work. The multifunction switch can be DIY refurbished for the brights issue, but I have never seen the wiper switch refurbished. Hope that helps,
Sincerely
-Jerry
PS. there are plenty of youtube videos showing how to replace the multifunction switch..
