Old Jun 23, 2023 | 09:21 AM
  #1193 (permalink)
xfClifford's Avatar
xfClifford
Default Re: SRT6 Serial Numbers ~ PDF format file...continued
Originally Posted by DTMenace
xfClifford
Thanks for the update on your "new" Crossfire SRT6. I've added your information on the specific line in the VIN database. The previous owner/forum member listed was TomSRT, as the 3rd owner. Did you purchase the SRT6 from him or another owner?
It looks to be in good shape, considering it has 177+ thousand miles on the odo.
Congrats on the purchase and many smiles in the future...
Regards,
Dennis
DTMenace
Purchased from Clint Spevak on 30/04/2023. He bought it roughly one year prior to me and it sat mostly un-used needing a ton of work.
As of 22/06/2023, it's had a new water pump, radiator, Belt tensioner, coolant tank, NeedsWings pulley saver kit, front supercharger seal and supercharger pulley bearing replaced, front tires, sticky key, RCM, VC gaskets, vintage JVC Arsenal radio installed, New (used) headlamp assemblies, Corner markers, most bulbs switched to LASFIT branded LEDs, Center support bearing, oil and filter changed, and transmission drain and fill done. Had PDR done to it to remove 42 dents, though some are still there. Current mileage is currently sitting at 178,700 miles.
