Old Mar 22, 2004 | 06:32 PM
AZ Outlaws's Avatar
AZ Outlaws
Default Re: Removing Center Console
Originally Posted by David Burns
Originally Posted by glennnn
When you removed the center console did you have access to the power window switches?
I don't get this power window switches thing. Is there something wrong with mine?
The "front" of the switch has a window icon. If I push the "front" of the switch, the windows go up. If I push the "back" of the switch, the windows go down. This feels correct to me. Am I just whacky, or are other people's cars wired different than mine?
Some of the cars had the switches reversed... pushing on the top side of the switch made the windows go down. Likewise pushing on the bottom, the windows went up... which is *** backwards.
It's easy to fix yourself. Pry up the shifter boot and then pull up on the center section of the console the boot was attached to. Press the tabs on both ends of the switch and pull the switch down and out. Then the switches have to be reversed and the icon over the switch needs to be gently pried off and reinstalled after the switch was reversed. Reinstall everything and it will work the way it was supposed to...
