Old Jul 11, 2023 | 06:48 PM
brasstacks2's Avatar
brasstacks2
Default Re: Erratic / Intermittent HVAC Blower / Fan Fix
Originally Posted by MoparDriver
I had the same symptoms until I didn't; that is it simply quit all-together.
Years ago I replaced the Blower Motor Regulator and that worked for about 4 years. Today, there is no fan (again, it was erratic for a while, then it stopped).
Moving forward,
1. I am a good w/electronics and solder, so I did the repair you suggested replacing the 47K rheostat with new. - no improvement.
2. I installed a second new Blower Motor Regulator, at the fan. No Improvement. The unit was very warm when I removed it after only a few minutes testing.
3. I removed the new Regulator and also the fan, did a 12VDC bench test on the fan motor and it ran well, nice a smooth.
4. I tested the readings on both regulators, the old one did not match the new one, but there were no dead shorts.
5. Lastly I tested the pins (Car Side) at the Regulator, found good steady voltage on RED/BLK and variable voltage on center pins when rotating the fan speed ****...
I am clueless on why this thing will not run.
Any thoughts?
I had the fan quit working but it started working again after hooking it up to 12 volts and reinstalling it. Depending on it's age and use the brushes may be too worn out and you may want to order a new fan. Also, the potentiometer replacement may not be exactly correct. If your a/c light turns on when turning up the potentiometer i would guess it is ok though. You may want to use electrical cleaner on the blower parts and run it a bit more on 12v and reinstall it and see if that works.
