Old Jul 12, 2023 | 02:52 PM
GraphiteGhost
Default Re: Erratic / Intermittent HVAC Blower / Fan Fix
Originally Posted by MoparDriver
"However the Recirculation selection does not appear to function"
The recerc button does not automatically operate the baffle system to circulate the inside air, it depends on the ambient temperature and a few other reported sensors that are programmed into the button's operation. It is hard to know when the recerc function will kick in, so give it a few different tries when the problems with the fan speed is resolved (your just working on one thing at a time and the recerc may not be a problem as of yet).
Also, just to remind you, the two 'rods' behind the A/C head MUST be correctly orientated within the receivers behind the A/C head. I believe they are slotted and only insert one way but again, they MUST be connected before the correct air directions can be realized. This is given only if nothing inside the air box is broken. Good luck!
