Old Jul 17, 2023 | 07:10 AM
CrossBlonde82's Avatar
CrossBlonde82
Default Re: MAF & Secondary air pump codes - I've tried everything!
Ok update 🤯🤯🤯 cleared codes after putting the rubber seal off the air filters in (paper removed) no engine light for 10 Miles car still a bit jerky.. Came back on codes have now changed.
The P0410 is now just a pending code not current so hopefully that's solved by new pump but being affected by the other issue?
New current code is P0101.. Any ideas, do I replace the MAF and see, I've put fuel cleaner in the tank incase anything like that or the CAT is dirty hoping that could help... The P0102 code has gone completely off the diagnostics, this is now the only current code.. MAF air flow out of parameters???? Help!
