Old Jul 17, 2023 | 03:35 PM
Ronman's Avatar
Ronman
Default Re: 2006 crossfire Limited Coupe BSA ESP light
Originally Posted by DVRITCHIE
what is causing my BSA ESP light to remain on? Is there a sensor or module to be changed?
Check to see if your brake lights work when you press brake pedal. Also, check to see if cruise control works when you try to enable it. If neither of those work then it is possible it is the brake light switch.
