Old Jul 21, 2023 | 04:02 PM
dedwards0323
Default Re: Hood release lever broken - replacement
[QUOTE=onehundred80;981188]
Originally Posted by dcskmail
The latch under the hood , I use white lithium grease. As far as the cable I've been using penetrating oil on both ends ,tape a cotton ball on both ends and soak it with lube it seems to eventually creep into the cable. This maintenance works for about every hinge point on the car, spoiler, hood, doors etc. & flap cables on the roadster. Here's a link for the hood release handle
https://www.autohausaz.com/pn/1248800320
[/QUOTE
I have no trust in lithium grease, it just sits there. Grease is at its best when it is physically placed between the moving parts. I use light machine oil on the latch, hinges etc. as it flows into gaps. Engine oil around SAE 30 or 40 would be fine.
I concur on using a light machine oil.
I would look into buying Motorcycle Cable Lube for the hood release cable. A search on eBay or Amazon will provide quite a few to choose from. Also available at many local Auto Part Stores.
