Old Jul 27, 2023 | 01:15 PM
tighed1's Avatar
tighed1
Default Re: July 2023 Car starting issues – probably the RCM
Back then I was only replacing the air pump relays. Now all of the relays (except horn, unless needed) are replaced because we know that they also go bad. That is what has happened here.
By the way, someone else has been working on that RCM.
Traction relay is failing. Email me at tighed1@hotmail.com for details on getting this refurbished.Send your RCM and $52 per RCM (includes return shipping in U.S.. Mention if outside of the US to get return shipping cost.) (cash, money order, check) to:
DJ TIGHE
SHIPPING TIP: USPS Flat Rate Small Box is about $10 and is the perfect size for one or two RCMs.
I'll inspect, bench test, redo bad solder joints, perform the Me So Horny mod (horn works w/o key) and replace the Air Pump, Fuel, Engine and Traction Control relays.
I will then test your RCM in one of my cars before mailing it back to you via USPS Priority Mail.
In most cases, I get the RCM back in the mail the day I receive it. Most folks get their RCM within a week of sending it.
Leave all fuses and plastic cover on RCM.
Let me know what symptoms the car had.
Please email your return shipping address to me also.
