Always something! Code P0007 and C101E
7/24/23
'06 Xfire Automatic: Used car all morning a few days ago and all was well. Tried using again around lunch time and it acted like it was only running on 3 cylinders and would not stay running,
7/28/23 Update:
'06 Xfire: Finally got around to pull codes for bad running and cuts off. Code C101E Mfg Control and P0007 Fuel Volume Regulator. Tried replacing RCM hoping it was a bad relay but got same bad results. P0007 is fuel cut off valve,"I think", and may need to be replaced. Don't know what it looks like and believe it's back by the fuel pump. (Anyone got a picture or a PN?) What is C101E code telling me?
UPDATE 3/24/23: Bought a better code reader and only code was P0101 (MASS Air Flow) The new meter did not pull the P0007 and C101E that was originally posted! This morning I finally got around to replacing the MAF Sensor and all is well now. I did the reset by shorting together the Pos and Neg cables, of course after removing them from the battery, and let it sit for about thirty minutes. Took for a test drive and no more codes and it runs fine with no issues. Thanks to all for your support and suggestions.
