cmaefs
I own a 2005 Crossfire Coupe. After I purchased it, I discovered the right front spring was cracked almost all the way through (2015). The dealer could not find OEM so we installed Eibach 2552.140 Pro-Kit Performance Spring Kit. The ride is horrible. It is like having no suspension at all. Hitting a pothole will rattle your teeth. Does anyone have a recommendation for a more compliant (Touring?) suspension system?
You went to a DEALER? All things aside, that was your first problem. Anyway, it is hard to make a compact sports car into a touring car. IF you want to get the suspension back (or close to) specs, see some of the local or far away salvage yards to see if they have 'OEM' spring(s) in pristine condition. Good luck.
