Old Aug 1, 2023 | 10:25 AM
zip439's Avatar
zip439
Default Re: Always something! Code P0007 and C101E
Originally Posted by Romad
7/24/23
'06 Xfire Automatic: Used car all morning a few days ago and all was well. Tried using again around lunch time and it acted like it was only running on 3 cylinders and would not stay running,
7/28/23 Update:
'06 Xfire: Finally got around to pull codes for bad running and cuts off. Code C101E Mfg Control and P0007 Fuel Volume Regulator. Tried replacing RCM hoping it was a bad relay but got same bad results. P0007 is fuel cut off valve,"I think", and may need to be replaced. Don't know what it looks like and believe it's back by the fuel pump. (Anyone got a picture or a PN?) What is C101E code telling me?
Those DTC codes make no sense. Neither are listed in the Crossfire Service Manual. Better luck with your new scanner.
