Old Aug 2, 2023 | 04:42 PM
DTMenace's Avatar
DTMenace
Default Re: engine shut down
rednrollin
There are two potential issues that could cause a "limp mode" scenario, one being the auxiliary water pump that is associated with the cooling of the supercharger, when the engine is running. The original Bosch pumps (ending in 03) failed numerous times in the past, beginning in 2005/06. Bosch redesigned the new pump (ending in 10) and they rarely fail.
The other potential issue is the RCM that may have failed. I doubt if the upgrades created this issue with your SRT6.
By using the SEARCH button at the top of the front page and inputting RCM or Auxiliary water pump, there will be numerous threads discussing this matter.
What were the temps, when you encountered this issue?
​​​​​​​Good Luck...
Dennis
​​​​​​​DTMenace
