Old Aug 6, 2023 | 08:08 AM
zip439's Avatar
zip439
Default Re: ESP/BAS Light // Stalling on streets
Originally Posted by RReyes
I have a 04 limited coupe. The wing work as it should, it goes up if manually activated or automatically when reaching 60mph.
Regarding to the cruise control I´m not sure I´ve never used it before, but that´s something i can verify.
How are these functions related to this issue?
Thanks for taking a moment to respond!
I was thinking the possibility of a bad brake light switch as the symptoms you mentioned fit the know solution. Thing is with the cruise control working and a functioning wing it dashes my initial theory as to a bad break light switch. I needed more information than your first post provided. Thus the questions.
It would help a good deal to get a scan of the Diagnostic Trouble Codes (DTC) otherwise it's just a guess with only the info you have provided.
