"experienced a couple of stuck ignition keys" ??? Yup, do the "sticky key fix" now if you can't tell that it has already been done. Some will write "Sticky Key" on the back of the inside driver side fuse panel if they performed it. There is no other way to tell if it was performed other than taking it all apart and seeing if that piece of crap metal and spring has been removed. If that key gets stuck the job gets much harder. This youtube upload from Paul has only been viewed 58,000 times... there is a reason it has been viewed so many times.
