Old Aug 10, 2023 | 07:07 PM
M60A3Driver
Default Re: Help! Spilled Water on window button and now window button won’t work.
Originally Posted by Gen
And is it hard to find a switch. How do I even access getting into that button to replace the switch. Can I get a generic switch or is this part hard to find as well?
do you think if I let it dry for a couple of days it would help?
It's easy to replace if you look at the instructions in the link ZERACER supplied.
It looks like you can just gently up your shifter boot using a plastic trim tool. Then you can gently pry up and pull back the plastic piece with the switches in it. You should be able to disconnect the switch from there and replace it with a new one.There is a whole bezel on fleabay and there are tested individual switches.
The link shows what it looks like:
https://www.ebay.com/itm/17578512432...0868690e6bfc9e
