Re: ABS Pump/Module
Dang, almost solved. Getting a RH wheel speed reading of 0 went through the manual and everything leads back to the module. Is there any source for a new module. Haven't had luck with used ones so far. Also get an ABS SPEED SENSOR NOT VALID error from the BCM error hex code 1268-00
