No crank after new keys
I purchased a 2005 limited with one key that wouldnt lock the doors for my step son. So I had rob at NEEDSWINGS reprogram my only working key and cut and program 2 additional keys. I reinstalled the skreem module, antenna ring and ecu and the keys paired flawlessly to the to the vehicle....except now it won't start!
I had zero issues before re installing the skreem, antenna ring and ecu. I put the battery terminals on with the key mistakenly in the on position. I was worried I might have fried the ecu so I tried to connect a code reader to my obd port and the reader now cannot connect to the ecu. I decided to replace the crank and camshaft sensors on a whim...no luck. I checked the rcm solder connections and fuses all good. I checked to see if the rcm was functioning with the key on. Everything functions when I manually close the relays. The 2 relays close when the key is in the start position (verified while the wife tried to start it). I ordered a new rcm incase my current one is somehow faulty.
Any ideas on where I should proceed next? I contacted Rob at NEEDSWINGS to see if he has seen this before. Any help is appreciated!
