Old Aug 12, 2023 | 08:09 PM
magnuman's Avatar
magnuman
Default Re: Crossfire Key Diode
Thanks Pizza Guy, although it would make sense that if th diodes were not working it might give you an indication of no power or something wrong.
I spoke with Josh and he still insists its not an issue with the SKREEM
I would gladly pull it out and send it to him.
I pulled my RCM today and it looks as new.
All solder joints, relays look great and no scorching at all.
This was Josh's last instruction.
I have ordered new pump to install.
"Disconnect the alarm and try a different locking pump. The SN line for lock/unlock confirmation via RF is not the same SN line that is used for the center console button. I’ve seen this a number of times. It is possible that your fob rolling code has become corrupt. If that is the case, there’s nothing you can do. However, I’ve only seen a very small number of people have that happen. Let alone two at the same time. You’re problem is wiring/mechanical"
