Zen Beer
DRBIII in abs module gives me a RF wheel speed sensor circuit line Monitoring ESP MK25 code: 1110
RF wheel speed sensor is reading 0 at all times. All diagnostics for testing the circuit back to CAB passed. Replaced sensor since 2 different ABS modules are reporting the same error. I didn't see a test procedure for the hub or checking air gap for proper operation.
I can't find what that error code means and think this is the last electrical gremlin to getting this car working.
It might be best to try another scanner and scan the car as a 2004 SLK 320. The DRB 3 emulator gives a weird code that isn't even in the service manual for a defective brake light switch. When I use an aftermarket scanner it specifically says stop lamp switch implausible.
