Re: ABS Pump/Module
still no luck on fixing this. I REALLY don't want to rip the wiring harness apart again. Should I be able to measure for AC voltage at the CAB connector to test the circuit from the sensor all the way up to the CAB? Or will spinning the wheel not generate enough voltage to get a reading? Thoughts?
