Old Aug 18, 2023 | 01:14 PM
GraphiteGhost
Default Re: 2006 XF engine stumbling.
Originally Posted by Romad
Still have to check later today. No time right now.
With the engine cover off (everything else buttoned up, don't let the spray go into intake), lightly spray some 'carb' cleaner around the rubber air lines (vac lines). IF the throttle jumps or makes it stall, you may have found the culprit. I did not forget the seems fine during (before) warmup.
I am guessing you DID a throttle body 'reset'?
