Romad
Hmmmmmm! Throttle body reset???? Uhhhh well maybe if I ever heard of something like that! Guess I'll have to look that up!
Update 18 Aug @ 3:50pm EST.......Doing it now and letting it sit for 30 min before attaching the battery cables.
Well that didn't work out so good! Hooked battery up, turned ignition on for about 3 or 4 minutes, turned key off and then started and it started right up. Let it idle for about 4 minutes and then gave it some gas. Smooth acceleration and everything was working beautiful. When temp got about 1/4 way up it started same ole hesitation and could not make it run at all. Tried several times and it just died. Last try it just cranked and cranked and then popped back thru the MAF! Closed hood and tomorrow I'll change the CPS with a new Bosch.
