Old Aug 31, 2023 | 01:08 PM
mariontr's Avatar
mariontr
Default Re: Any info or cowl leaks?
ala_xfire what do you mean by "TCU" in "dry passenger floorboard and possibly replace amplifier and TCU"? With the last storms we had in South FL, the car has sat for two or more weeks while I was out of state and on return I noticed just yesterday when took the car for a spin that I heard slushing water sounds and on checking when I returned home the passenger side carpet was soaked filled. Just use wet-vac to get what water had settled in the carpet on the passenger side. Have damp rid sitting on the floor as well as a portable dehumidifier running. I assume when I remove the panel where you can access the blower motor the rest of the water it what I heard slushing, correct? So I'll most likely have to replace the blower motor and resistor. Thanks for the forum help as always.
