Old Sep 2, 2023 | 12:03 PM
mariontr's Avatar
mariontr
Default Re: Any info or cowl leaks?
Forget part numbers and forget eBay. You want the TCU from the same year range and model variant as your car:
2004-2006 or 2007-2008
Limited or SRT
Get one from a 'parts car' not off eBay.
ALSO: If the module is damaged, the harness is corroded as well. I would get in there and determine if there is water damage or not. If you were lucky, the water never got to the TCU or it's connector. If it did, you need the last few feet of the wiring harness as well, you CAN NOT clean the corrosion from inside the connector pins.
If yours is damaged, we can find a parts car. Zach in SC and Cliff/Eric in Ohio both have parts and access to parts cars.
Thanks for the advice, but weather has not been my friend in South FL, these past couple of days and it has rained just about everyday (nights) since it is parked outside I am getting despondent and frustrated that I know what needs to happen but just need some cooperation from mother nature. I have a car cover on order that at least would alleviate the rain from entering the car. Well so much for my rant...
