pizzaguy
I think you mean CRANKSHAFT sensor. The reason you dropped it is because you did not use my trick.
I could tell, the chance of dropping that damn screw was 99.999999% before I even started the job. Altho I admit, I thought the most likely time to drop it would be during removal.
Same bolt for camshaft or crankshaft sensor. I use a magnet to pick up the bolt once it is loose.
