Old Sep 9, 2023 | 03:48 PM
GraphiteGhost
Default Re: Brake Lamps On/Electrical Problem
Originally Posted by zip439
I saw that Ghost, but it is just a block diagram without the internals to the switch as in post #19 above and nothing in the 2008 shows wiring actually running to the lights as Pizza indicates in his #19 above. I couldn't find anything in the rear lighting section of the 2008 that showed the brake lights and some of the connection numbers are different. I may have missed something,; other than changing out the switch or the bulbs I hope I never have a need to get any farther into it.
Pizza, maybe start a sticky with known errors in the service manual.
Zip, sure does a tangled web of wiring based on that block diagram. To be sure, the connector numbers referenced may or may not also be an error. Although I haven't opened up the downloadable different service manuals (to check/verify the 08), that might be a good place to start, to see if they were changed at the 2005 or later model year manuals that are available. The page references in this post refer to the 04 manual (and I am not too sure of the manual or auto transmission being referenced).
