Re: Brake Lamps On/Electrical Problem
I have a 2004 roadster and replaced my stop light switch without dropping dash. i hat a mirror and a flashlight and could spot the switch near top of brake pedal. if you can open the car door and get on the floor and reach up and feel the switch, turn it clockwise to remove and counter clockwise to replace. The plug will only go in to switch one way on side marked A. After installing wire plug into switch, reach up untill you feel the hole for the switch. insert it lightly and rotate the switch around opening until the tab on the switch goes into the slot on the mount, and then push and turn hard counter clockwise until it clicks. Not easy but worked for me.
