Old Sep 14, 2023 | 06:37 PM
JSK's Avatar
JSK
Default Re: Headlight problem
Originally Posted by BPCR45-70
Thanks Tom. I watched this video, and others, a couple times along with some written tutorials before I started the job.
I paid special attention to make double sure the tab was seated in the housing at 6 oclock for the low beam unit. The connector prongs for the plug are at 6 ocklock and 12 oclock which verifies the bulb is in their correctly.
Something else must be going on in there and I'll have to figure it out. Now, one thing I noticed while fiddling with this is that the whole low beam unit wiggles a little bit when I was working with the bulb. Not the whole low/high beam assembly, just the big plastic silver round housing. Is that unit supposed to be rock solid?
Can you see the light assembly behind the lens moving up and down when you turn the adjuster? It is not uncommon for the adjuster screw to pop out of the retainer on the back of the light or the retainer even breaking.
