Originally Posted by MMZ_TimeLord
Is it accurate as before you installed the Sprint Booster?
If so, then maybe it's not the actual position that's being 'boosted'. Maybe it's the signal that tells the ECU "I'm pressing FAST".?
Just a thought...
I bought the scanner after I had already installed the SB, so I'd have to pull it and re-run the test. However it'd be hard to get any "real" comparison between the two tests without putting some sort of pedal stop to limit how far I could push the pedal.
But what I observed was that although it revs quickly the throttle position reported over the OBD-II didn't seem to increase as quickly...
