Old Sep 21, 2023 | 02:21 PM
jtammel's Avatar
jtammel
Default Re: Lower valve cover leak
All I can say, is that I ordered the kit from Needswings when I fixed my leaking breathers. I took both valve and breather covers off the car, separated them, cleaned them extensively, let them dry overnight, then put on new gaskets and NEW BOLTS as well as using Max's technique in application of RTV. This was in 2016. No leaking even now, seven years later.
Total time: probably close to six-seven hours not counting drying time. I took my time, quick fixes don't last.
Breather covers are dry. I did basically how you described, let the RTV sealant sit for a while before installing the breathers and used new bolts. I guess that is why the breathers are dry.
Lower ones with the factory gasket is the issue.
