Parking brake, rear pads, and hardware
Sep 25, 2023 | 01:40 PM
permalink
xintersecty
Aug 2023
346
205
Columbia SC
Re: Parking brake, rear pads, and hardware
Between Rock Auto and FPC, I have parts. Except...one very important part: the pin holding the cable to the activation lever. I bought a 1/4 inch brass rod, which is slightly bigger than. the 5.68mm I measured inside the hole. Using my drill press, I put together a honing jig.
brass rod and lever
Using various grits of sandpaper I got the diameter to fit perfectly with a slight taper.
Pin and lever
It fits!
Pin fitted in the lever
Of course when I went to remove the disc on the passenger side, somebody screwed up the retaining screw.
This is not coming out with regular star tools.
Fortunately I have a effing clue on how to fix this.
Screw extraction tool to the rescue
M60A3Driver
xintersecty
View Public Profile
Send a private message to xintersecty
Find all posts by xintersecty
