Old Sep 30, 2023 | 07:04 PM
Platterus's Avatar
Platterus
Default Roof bucking and window bow won't drop into place.
I found a hydraulic line disconnected on Main lift cylinders beside reservoir in trunk. Got that filled up after several cycles of raising and lowering the roof. Found an issue with decklid not locking in place properly when putting roof back up, and whole roof assembly bucking when window bow is supposed to drop into deck lid. Any ideas what my issue can be? I'm just waiting for pressure to relieve on window so it closes again. Tried using 10mm box wrench to manually lock and unlock deck, but it doesn't seem to even be able to find the flat portion on release.
The deck lid bounces like its searching for it's position when I try using switch to close it.
