Old Oct 6, 2023 | 04:53 PM
Ronman's Avatar
Ronman
Default Re: Completed Sticky Key fix caused Exterior Bulb Failure?
Originally Posted by SapphireCrisis
Hi everyone!
Relatively new owner of a 2004 Automatic Crossfire. I bought the car last month with a very bad case of Sticky Key, and last week I completed the fix thanks to the forum! However, now that I've reinstalled the dash and everything, all 3 brake lights are out, and the "Exterior Bulb Failure" light is on. When I brought the car home, the brake lights worked, and the EBF light wasn't illuminated. Curiously, the EBF light only turns on when the headlights are switched to the on position, and all of the rest of the lights seem to be in working order. I've already ordered a new Brake Light Switch. I'm wondering if anyone else has experienced something similar, or knows outright what the problem is. I'm guessing I dislodged or goofed something up removing/reinstalling the dash, but I'm kind of baffled at the correlation between the EBF and Brake Light Switch, if that is indeed my problem.
Thanks for reading!
Brake light switch failure does not cause exterior bulb failure light to come on. Usually the BAS/ESP light comes on, you cannot shift out of park, brake lights do not come on at all or cruise control does not work.
