Old Oct 7, 2006 | 01:55 PM
stryfox's Avatar
stryfox
Default Re: McCulloch Xenon HID Conversion Kit
Originally Posted by andrew
the "plug and play" kit is easy to install. total install time... an hour or two. no cutting... no splicing... just plugs into the factory harness.
the kit comes with xenon bulbs, ballast, relay etc...
you will need to order the "H7" kit. i would recommend the 6,000k.
ebay link (under $300)...
http://cgi.ebay.com/ebaymotors/McCul...18972624QQrdZ1
installed in my car...here are the pics of where i mounted the hid hardware (you must have a flat surface). the relays are mounted using existing posts...i added a nut to secure relay. extra wire ties keep things nice and tightie (lots of extra wire).
drivers side:
passenger side:
Andrew,
How's it going?
Was good to meet you out at carlisle.
Would you buy the 6,000k again?
I am trying to decide between 5,000, 6,000, 8,000.
I rarely use my high beams as being in the city there are not too many opportunities to do so, darn traffic.
Basically are you happy with the 6,000 single kit?
If you did it again would you change anything?
Do you feel it is worth doing the fog lamps too?
Thanks for any info.
