Old Oct 9, 2023 | 10:58 PM
GraphiteGhost
Default Re: Cant control fan location, blows out every vent all the time.
Originally Posted by Travish
After searching I still come up blank. I always search trying to figure issues out so as to not to be a pain.
I see bunches of fan issues including disconnected **** shafts, blower resistors (I think i changed that) vacuum line under the battery tray and others.
My fan blows out all vents all the time. The fan speed works fine. The temperature works. I have just been dealing with it by rolling the vents closed but besides that dang esp light EVERYTHING works perfect and it been bothering me more and more.
I have the Kenwood radio installed but I don't think the problem originates from that unless the **** shafts are actually unhooked. Any suggestions before I tear the dash apart?
Thanks
It might be the two duct shafts are not connected to the HVAC control head (as you say 'unhooked'). If I were you, I would remove the HVAC control head and reinstall it with the two interconnecting shafts behind the head into the keyed slots on the head. They sometimes are a bear to get them lined up right but once slipped into the keyed slots your directional control may return. If this isn't the case, come back and let us know any additional information since some aren't clear about the issue you have. Good luck!
