Re: Input needed
I don't know the name of it but it has a elect plug on it with a 90* turn vacuum line on one side and a clamped vacuum line on the other it is located under hood drivers side next to shock tower
replace that,,, P0444 gone and car will run better. jim
edit: i assumed you changed the RCM and you still had po444 , thanks Mark sometime i assume too much...
